Extract mid-string characters
The SubString function extracts from a text field starting at a specified position (defined using the first #) and continuing for a specified number of characters (defined with the second #).
Function: SubString(Parameter,#,#)
Example Explanation Old value New value
If: Activity ID = AADRAW000 Selects activity AADRAW000
Then: Activity ID = SubString(Activity ID,4,3) Extracts three characters, beginning with the fourth. AADRAW000 RAW
