Format grouping bands
  1. Choose View, Group and Sort By, or View, Group and Sort By, Customize.
  2. Double-click the Font & Color cell you want to change. Click the Font box to change the text properties. Click the Color box to change the grouping band color.
  3. Mark the appropriate checkbox to determine the text that displays on the grouping band. To display the field name on the grouping band, mark the Show Title checkbox. To display the ID or Code value on the grouping band, mark the Show ID/Code checkbox. To display the Name or Description on the grouping band, mark the Show Name/Description checkbox.
