Group activities by field
- Choose Project, Activities, then choose View, Group and Sort By.
- In the Group By section, click the cell, then select the item by which you want to group.
- Click Sort, then select a sort order for the group. Click OK.
- To change a grouping band's attributes, such as the color and font, double-click the appropriate Font & Color field.
- To group by additional items (up to 20 levels), repeat step 2.
Tip:
To remove a field, select the field you want to remove, then click Delete.
In the Activity Network, when you select a field grouping, the hierarchy on the left side of the window contains the WBS hierarchy so you can filter activities according to the hierarchy.
