Installing Local Copies of P6 Professional and Visualizer Help
By default, online help for P6 Professional and Visualizer is hosted by Oracle. If you prefer to access Help locally, you can install a local copy of the Help.
The hosted versions always contain the most current version of P6 Professional and Visualizer help.
To install a local of the P6 Professional and Visualizer help, complete the following steps:
  1. Download the Downloadable P6 Professional Help and extract it locally.
  2. In the extracted zip file, double-click P6ProHelpInstaller.msi to launch the installation wizard.
  3. Click Next.
  4. Expand Local Help Files.
  5. Do the following to install a local copy of P6 Professional help.
    1. Expand PM Help.
    2. Click the drop-down for the language you use in the P6 Professional user interface and select Will be installed on local hard drive.
      P6 Professional Help is available in English, French, German, Japanese, and simplified Chinese. Selecting any other language installs Help in English.
  6. Do the following to install a local copy of Visualizer Help.
    1. Expand Visualizer Help.
    2. Click the drop-down for the language you use in the Visualizer user interface and select Will be installed on local hard drive.
      Visualizer Help is available in English only. Selecting any other language installs Help in English.
  7. Click Next.
  8. Click Install.
  9. Click Finish.
