Load resource summary data at startup
  1. Choose Edit, User Preferences.
  2. Click the Startup Filters tab.
  3. Select the Resource and role summaries option to load resource summary data at startup.
If you choose to load the data at startup, P6 Professional may take longer to start and some views may take longer to load.
When connected to a P6 Professional database, in addition to the resource summary data that may be affected in P6 Professional and P6 EPPM databases, resource and role data may be affected during project summarization.
