Modify a spreadsheet field title in a tracking layout
- Click the Display Options bar in the layout displaying the spreadsheet, then choose Top Layout Options or Bottom Layout Options, Spreadsheet Fields, Customize.
- In the Available Options area, select the spreadsheet field whose title you want to change, then click Edit Title.
- Type a new title, specify its width and choose an alignment, then click OK. To preview the new title without closing the dialog box, click Apply.
