Module access (P6 Professional Only)
The P6 Professional module access option controls whether users can attempt to log into the P6 Professional application.
The Visualizer module access option controls whether users can attempt to log into the Visualizer application.
For each defined user, a user with the required security privilege can enable or disable access to the products listed in the Users dialog box (choose Admin, Users, then click the Module Access tab).
