Move toolbar icons
Using your mouse, you can change the position of icons within a toolbar, or move an icon to a different toolbar.
  1. Choose View, Toolbars, Customize, to open the Customize dialog box.
    Opening the Customize dialog box switches the toolbars into Edit mode, which enables you to move icons. You do not need to use the Customize dialog to move icons; however, you must leave the dialog open to enable you to move icons.
  2. To move an icon, select it in the toolbar, then drag it to the appropriate location.
    You can place the icon at the beginning or end of any displayed toolbar, or between any two displayed icons. You can not place the icon outside of a displayed toolbar.
  3. When you are finished moving icons, click Close in the Customize dialog box.
Tip:
You can revert to the default settings for an individual toolbar, or for all toolbars.
