Personal Information (PI) Data in P6 Professional
PI may be visible in multiple areas of P6 Professional, including but not limited to user administration, resource and role administration, assignments, work products and documents, reports, issues, notebooks, risks, user defined fields, codes, calendars, project websites, P6 Visualizer, and timesheets.
PI may be at risk of exposure in multiple areas of P6 Professional, including but not limited to project export, downloaded tables, reports, documents, project websites, API, and log files.
As part of the Primavera Virtual Desktop Cloud Service, you may be using an identity domain to manage your user access and entitlements across a number of cloud and on-premises applications and services. If you are using or accessing an identity domain, you are responsible for deleting your details and data from the identity domain environment. You are responsible for retrieving your content in the identity domain during your applicable services period.
