Promote EPS-level activity codes and values
You can promote, or change, an EPS-level activity code and its values to a global activity code with global values.
  1. Choose Enterprise, Activity Codes.
  2. Choose EPS, then click Modify.
  3. Select the code you want to promote, then click Make Global.
  4. Click Yes, then click Close.
Tip:
If you promote an EPS-level activity code and its values, your change applies to all activity assignments.
