Publish activity and tracking layouts on a Project Website
Before you publish a project as a Web site for the first time, you might choose to create a new folder on your computer or network or verify that the existing folder you want to use is empty.
  1. Open the project you want to publish.
  2. Choose Tools, Publish, Project Web Site.
  3. Click the Graphics tab.
  4. Mark the Include in Project Web Site checkbox to include activity and/or tracking layouts in the project Web site.
  5. In the Activity Layouts section, click the Assign button, select the activity layouts you want to include in the Web site, then click the Select button.
  6. In the Tracking Layouts section, click the Assign button, select the tracking layouts you want to include in the Web site, then click the Select button.
  7. Click Publish. If the folder you selected contains older Web site files or other files, a message warns you that those files will be deleted. Choose Yes to continue or No to cancel. The layouts are added to the project Web site's HTML folder.
