Publish Toolbar
Use the Publish toolbar to publish a project Web site, activity layouts, and tracking layouts.
By default, this toolbar is not displayed.
The following table provides information about each available icon on the toolbar.
Icon Function Corresponding menu command
"" Opens the Publish Project Web Site dialog box. Use the Publish Project Web Site dialog box to save the project information you specify as HTML files. You can then publish these files as a Web site on an intranet or the Internet. Tools > Publish > Project Web Site
"" Opens the Select Activity Layouts to Publish dialog box. Use the Select Activity Layouts to Publish dialog box to specify the activity layouts to publish to the project Web Site. Tools > Publish > Activity Layouts
"" Opens the Select Tracking Layouts to Publish dialog box. Use the Select Tracking Layouts to Publish dialog box to specify Tracking layouts to publish on the project Web site. Tools > Publish > Tracking Layouts
Tip:
  • All of the icons on this toolbar display by default when you choose to show the toolbar.
  • The icons on this toolbar do not have corresponding shortcut keys.
