Relationships
A relationship defines how an activity relates to the start or finish of another activity or assignment. Add relationships between activities to create a path through your schedule from the first activity to the last activity. These relationships, which form the logic of the project network, are used together with activity durations to determine schedule dates. An activity can have as many relationships as necessary to model the work that must be done. You can enter comments about a relationship, for example to explain the need for the relationship or how it is configured. You can also identify relationships between activities that are in different projects; this type of relationship is referred to as an external relationship.
Choose from the following types of relationships:
Finish to start relationship
Finish to finish relationship
Start to start relationship
Start to finish relationship
Tip
The default relationship type for all activities (including start milestones) is finish to start.
