Remove projects from a portfolio
  1. Choose Enterprise, Project Portfolios.
  2. Select the portfolio from which you want to remove projects.
  3. Click the Projects tab.
  4. Select the projects you want to remove. To remove multiple projects, hold down the Ctrl key, then click each project you want to remove from the portfolio.
  5. Click Remove.
  6. Click Yes.
Tip:
You cannot remove projects from a filtered portfolio. Filtered portfolios select the projects on the basis of criteria specified in their filter.
