Remove roles from resources in the Roles dialog box
You can remove a role from a resource in the Resources window, or you can remove a role from a resource in the Roles dialog box.
- Choose Enterprise, Roles.
- Select the role you want to remove, then click the Resources tab.
- Select the resource from which you want to remove the role, then click Remove.
- Click Yes.
