Removing risk assignments from activities (P6 Professional Only)
You can remove the assignment of a risk to an activity using the Risks view or while managing your activities using the Activities window.
To remove the assignment of a risk to activities from the Risks window:
  1. If you haven't already done so, do the following to display the Risks details:
    1. Choose Project, Risks.
    2. Display Risk Details, then click the Activities tab.
  2. Select the risk with the activity assignment to remove.
  3. On the Activities tab:
    1. Select the activity to remove.
      To remove multiple activities, hold down the Ctrl key, then click each activity to remove.
    2. Click Remove.
To remove the assignment of a risk to activities from the Activities window:
  1. If you haven't already done so, do the following to display the Activity Details:
    1. Choose Project, Activities.
  2. Display Activity Details, then click the Risks tab.
  3. Select the activity with the risk assignment to remove.
  4. On the Risks tab:
    1. Select the risk to remove.
      To remove multiple risks, hold down the Ctrl key, then click each risk to remove.
    2. Click Remove.
