Rename document categories (P6 Professional Only)
  1. Choose Admin, Admin Categories.
  2. Click the Document Categories tab.
  3. Double-click the category whose name you want to change, then type the document category's new name.
Tip:
  • To change the order in which document categories are listed, select the document category you want to move, then click Shift Up or Shift Down.
  • If you change a document category's name, your change applies to all document items assigned that category.
