Rename expense categories (P6 Professional Only)
- Choose Admin, Admin Categories.
- Click the Expense Categories tab.
- Double-click the category whose name you want to change, then type the expense category's new name.
Tip:
- To change the order in which expense categories are listed, select the expense category you want to move, then click Shift Up or Shift Down.
- If you change an expense category's name, your change applies to all expense items assigned that category.
