Reset toolbars and menus to factory defaults
You can reset all P6 Professional toolbars and menus, or an individual toolbar, to factory default settings. When you reset toolbars, only P6 Professional toolbars are reset, not custom ones.
- To reset all toolbars and menus, choose View, Reset All Toolbars. When you reset all toolbars and menus, all modifications to P6 Professional toolbars and menus are lost.
- To reset an individual toolbar, choose View, Toolbars, Customize. On the Toolbars tab, select the toolbar you want to reset, then click Reset. You can also reset an individual toolbar when you show or hide toolbar icons.
