Resource Explorer window
The Resource Explorer window displays in the left pane of the Tracking Bottom Layout window when a Resource Analysis layout is open. See Resource Analysis layouts. You can choose to arrange the resource information in this window according to resource or role and you can filter, group and sort resources, and specify which column data you want to display.
- To change the display options in the Resource Explorer window, click the Display Options bar.
- To display data in the current layout for a resource element, click the element in the Resource Explorer window.
- When resource security is enabled (you have limited or no resource access), the layout options behave the following way.
- The Current Project's Resources option displays the current project resources of the currently selected project only.
- The All Resources and All Active Resources options display all (active) resources you have access to, and all current project resources for all the projects you select. As you select another project, its current project resources are added to the resource list. This list gets cleared only when you exit P6 Professional. If you want to view the current project resources only for the currently selected project, choose the Current Project's Resources option.
