Select and assign information
Many of the fields provide a Select dialog box that lists the available entries.
- Click
in the field or
in the open tab or dialog box.
- Select the item you want to use, then click
. - Or - To replace a value, click
. To remove a value, click
. - If necessary, click
In some tabs and dialog boxes, you can remove an item by selecting it and clicking
