Send Email about an issue
You can send Email about an issue from the Project Issues window or the Issue Navigator dialog box.
  1. From the Project Issues window, select the issue about which you want to send Email, then click
    on the Edit toolbar, or right-click on the issue and choose Notify. From the Issue Navigator dialog box, select the issue about which you want to send Email, then click Notify.
  2. In the Subject and Contents area, type any corrections or additions about the issue.
  3. To add a recipient, click Add. To select a recipient from a list of OBS members, resources, or users, choose Select Recipient from a Dialog, then click OK. Select a recipient from the displayed dialog box, then click the Assign button. To enter a recipient's Email address, choose Manually Add a New Recipient, then click OK. Type the recipient's information in the Notify Issue dialog box.
  4. To remove a recipient from the recipient list, select the recipient, then click Remove.
  5. To send the notification to all listed recipients, click Send All.
Tip:
The recipients you choose to notify about an issue are not saved in the Recipients list in the Notify Issue dialog box. To keep a record of who you Emailed about an issue, you can add the information to the issue history.
