Set the Online Help location (P6 Professional Only)
  1. Choose Admin, Admin Preferences.
  2. Click the Options tab.
  3. In the P6 Professional Online Help URL field: Leave the default URL to launch the version of the Help hosted by Oracle when Online Help is selected from the Help menu. Remove the URL to disable the Online Help option from the Help menu for all users. Users will only be able to access the local version of the help. Specify a new URL location to launch when Online Help is selected from the Help menu.
  4. The Always launch Online Help for the F1 shortcut key and context-sensitive help option is not selected by default. To always launch online help for F1 key and help shortcuts, select this option.
    • Using the hosted version ensures that you always have the most current help content.
    • Clicking on Online Help will launch the URL specified in Admin Preferences.
    • If the P6 Professional Online Help URL field is blank, the Always launch Online Help for the F1 shortcut key and context-sensitive help option is disabled.
    • When connected to a P6 EPPM database: Use P6 to set the online help location.
