Text Qualifier
If you import or export information that contains the field delimiter you specify, this character separates fields or categories of information. For example, if you select comma (,) as the field delimiter and single quotes (') as the text qualifier, 'Smith, Bob', 55.00, 123-4567 imports/exports as three categories of information, not four.
