Threshold parameter definitions
A threshold parameter is a type of "test" that P6 Professional applies to activities or work breakdown structure (WBS) elements in a project to identify potential issues. You can specify a threshold parameter and a lower and/or upper threshold value against which project data can be evaluated to identify issues that you want to track.
An issue is automatically generated when a threshold parameter is equal to or less than the lower threshold value, or equal to or greater than the upper threshold value.
The following list defines the available threshold parameters:
Accounting Variance ($)
Cost % of Planned (%)
Cost Performance Index (CPI) (ratio)
Cost Variance (CV) ($)
Cost Variance Index (CVI) (ratio)
Duration % of Original (%)
Finish Date Variance (days)
Free Float (days)
Schedule Performance Index (SPI) (ratio)
Schedule Variance (SV) ($)
Schedule Variance Index (SVI) (ratio)
Start Date Variance (days)
Total Float (days)
Variance at Completion (VAC) ($)
