Timesheets overview
With the optional P6 Team Member Web module installed, users can submit timesheets reflecting their work assignments on projects. Timesheet approval managers can then approve or reject those timesheets.
Timesheets allow the user to record hours for assigned activities. Timesheets are assigned a period and an approval level. The period defines the amount of time the timesheet covers, lasting from one week to a month, and what day of the week will conclude the timesheet. The approval level specifies how many levels of approval are necessary to submit a timesheet. Approval levels range anywhere from no approval required to two approval levels.
After a resource completes an online timesheet, the assigned approval manager for the resource, or a designated delegate, then performs any of the following tasks in P6 Professional:
  • approves or rejects the timesheet
  • notifies the resource about the status of the timesheet
  • views/determines if a resource has started or submitted a particular timesheet
  • adds timesheet notes
    If you are a timesheet approval delegate for a project manager, you can review timesheets for resources who are assigned to activities within the projects for which you have been granted approval rights. A project manager can transfer timesheet approval rights to different delegates for each project.
