Use the issue navigator
- Choose Tools, Issue Navigator.
- Select the issue you want to review.
- To view the issue's details with its assigned tracking layout, click Tracking. To view the issue's Activity Details in the Activities window, click Activities. To view the issue's work breakdown structure details in the Work Breakdown Structure window, click WBS. To view the issue's resource details in the Resources window, click Resources. To view the issue's details in the Project Issues window, click Issue Details.
Tip:
You can automatically display the Issue Navigator at startup. Choose Edit, User Preferences. Click the Application tab, then mark the Show the Issue Navigator Dialog at Startup checkbox.
