View activity relationships in Activity Details
Activity Details list the selected activity's relationships and details, such as activity type, in different tabs.
  1. Select the activity whose relationships you want to view.
  2. Click the Layout Options bar, then choose Show on Bottom, Activity Details.
  3. To view the selected activity's predecessors, click the Predecessors or Relationships tab.
  4. To view the selected activity's successors, click the Successors or Relationships tab.
Tip:
  • If the Predecessors, Successors, or Relationships tab is not displayed, click the Layout Options bar, then choose Bottom Layout Options and add the missing tab to the Display Tabs column list.
  • To change the displayed columns within each tab, right-click anywhere in the tab, then choose Customize Predecessor Columns or Customize Successor Columns.
