View the check-out status of a project
- Choose Enterprise, Projects. A red check mark displays beside any project that is currently checked out.
- Choose View, Show on Bottom, Project Details.
- Click the General tab, and check the status of the project in the Check Out Status field. Privileged users can also change the status of a project in this field.
The Checked Out By field indicates the user that checked out the project.
The Date Checked Out field indicates the date and time the user checked out the project.
- Changing the status of a project to Checked Out or Checked In, in the General tab, does not export project information or import updated project information. To import or export information when checking in or out a project, select Check In or Check Out on the File menu.
- The Checked Out By and Date Checked Out fields are blank when the Check Out Status is Checked In.
