View the OBS
You can view an organizational breakdown structure (OBS) in two ways. You can use the OBS chart to view a graphical display of information, and you can use the OBS table to view information in a column format.
- Choose Enterprise, OBS.
- If the Organizational Breakdown Structure dialog box currently displays the Chart View, click the Display Options bar and choose Table View.
- To view the OBS hierarchy, click the OBS Name column label.
- To list and sort OBS elements, click the OBS Name column label again.
