View the WBS
- Choose Project, WBS. To view the WBS as a graphical chart, choose View, Show on Top, Chart View. To view the WBS as a table in column format, choose View, Show on Top, Table. To view the WBS as a table in a column format with a corresponding Bar Chart, choose View, Show on Top, Gantt Chart.
Tip:
You can also select the same View commands by clicking the Display Options bar.
