Wizards
Wizards are a great way to speed up your work. They quickly guide you through repetitive tasks, doing most of the work for you.
The wizards help you
- Create projects
- Add activities
- Add resources
- Create reports
- Import projects
- Export projects
- Check in projects
- Check out projects
You can choose to launch the New Activity and New Resource wizards automatically when you add a resource or activity. Other wizards are available when you select the applicable menu option, for example, project check in/check out, or when you select a dialog box option.
