Codes Detail Window of the Assignments Page
Overview
Use this detail window to assign codes to resource and role assignments. You can also view assigned project, activity, resource, and role codes when you select the relevant grouping band. The data you see in project, activity, resource, and role grouping bands is read only on this page.
Screen Elements
Assign... button.
Opens the Select Assignment Code dialog box. To see this button, you must select an assignment.
"" Search
Searches the view or dialog box for data matching the criteria entered into the box.
"" Context menu
Delete: Deletes the selected item.
Codes detail window columns
Name field
The name of the code.
Value field
The alphanumeric or descriptive value of the code.
Description field
A description of the code or the code value.
Getting Here
  1. Click "" Navigation Menu.
  2. On the Navigation Menu:
    • Expand "" Projects and click Assignments.
    • Or expand "" Resources and click Assignments.
  3. Select an assignment.
  4. Click the Codes detail window.
