Updating the Progress of Activities Using Email Statusing Service
If Email Statusing Service is configured at your organization, you can request a list of your assigned activities using email. Then, you can reply with your status updates.
To update your status using email:
A confirmation message will be sent to you after your updates have been processed.
If you need assistance with the options, syntax, or required formatting of these messages, send an email message with only the word "Help" or a question mark in the subject line to receive more detailed instructions.
