About Filters
A filter is a set of instructions that determines which data display in the current window. You can create filters or use the predefined filters available in the application. There are three types of filters: user-defined, global, or standard. User-defined filters can be created for multiple users or only the creator of the filter. Global filters are available to all users for all projects. Standard filters are also available to all users for all projects; however, users cannot modify standard filters. You can apply a combination of filters to narrow the data selection even further. Filters are available on the EPS, Activities, and Assignments pages.
