About Find, Search, and Filter Features
The application provides three main ways to find the data you need: Find, Search, and Filter.
The Find feature is available in tables to help you find the next matching row in a column. Use the Find feature in table columns to locate matching rows of data one at a time up or down the table.
  • For pages with static data, use the Find feature in your web browser to locate fixed elements of the user interface. See the help documentation for your web browser.
  • You can also use Replace with Find, for example if you want to replace one word with another throughout a project.
The Search feature is available on certain pages or dialog boxes to help you reduce the number of available values, showing only those values that meet your search criteria. Use the Search feature wherever it is available to locate only matching values.
The Filter feature is available on certain pages to help you reduce the amount of data in tables, showing only those values that meet your filter criteria. Use the Filter feature wherever it is available to view only matching values. For example, you might configure a view with pre-defined filter, group, and sort parameters.
