About the Activity Table and Grid View
The Grid View presents all WBS and activity information for the currently open projects in a familiar table format. You can customize Grid View columns.
For example, you might change the information displayed in columns to show scheduling data, resource and cost data, user-defined fields, or any data items you select, including calculated data.
Use the Grid View to:
  • Create a list of activities and activity information quickly when you don't need to see the information graphically over time as in a Gantt chart.
  • View all the activities for the currently open projects grouped by project and WBS.
  • Sort activities to arrange them in an order you specify. For example, to view activities chronologically, you might sort them by a date field.
