About User Interface Views
A user interface view is a pre-configured set of options you assign to users so their view of Dashboards, Portfolios, Projects, Resources, and Administration is optimized for their role. User interface views permit visibility to features essential for a user's role while hiding functionality that is not applicable.
Users with the same or similar roles can be assigned parallel views. To further enhance a role-specific configuration, you can:
- Assign specific views to open by default when a user assigned to the User Interface View opens the EPS, Activities, or Assignments pages.
- Assign global dashboards and multi-user dashboards to a user interface view.
If you assign a multi-user dashboard to a user interface view, only users who have access to the dashboard as specified on the Access tab of the Create Dashboard page can view the dashboard. Users who have access to Manage Dashboards (in the Dashboards menu) enabled in their view can use the Manage Dashboards page to create dashboards and choose which dashboards are displayed on their dashboards home page. Users who have the right to edit user interface views can modify their views to suit their needs.
