About User Sessions
Manage user sessions to view a list of active users, or to reset users that are locked out of P6, P6 Team Member Web, P6 for Android, P6 for iOS, or P6 Professional. Locked-out users are unable to initiate new sessions because they have violated login constraints set in P6 Administrator application. For example, users may become locked out if they have attempted to log in while a session is already running, or if they have repeatedly entered incorrect login information.
If you reset a user's session while they are using P6, P6 Team Member Web, P6 for Android, P6 for iOS or P6 Professional, their session will be ended and they will need to log back in again. Users of P6 Professional might not be aware that their session has ended for up to five minutes. Data changes they make after their session is ended will be lost. Therefore, it is important to let users know you will be resetting their session before hand wherever possible.
The User Sessions page displays:
- Users who are currently logged in to the application, and the time of their last activity
- Users who have left the application, but did not log out
- Users whose failed login count exceeds the acceptable threshold set in the P6 Administrator application
