Actual Units (Assignments)
Actual Units field
The sum of the actual non-overtime and the overtime units worked by the resource on the activity.
Calculated as Actual Regular Units plus Actual Overtime Units.
Values for Actual Regular Units and Actual Overtime Units are obtained from either timesheets when project actuals are applied, or directly from the updated fields in the interface.
