Adding Activity Steps from a Step Template
You can add steps from a step template to add a group of predefined steps to an activity.
To add steps from a step template to an activity:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select an activity and click the Steps detail window.
- In the Steps detail window, click Assign....
- In the Select Activity Step Template dialog box, select a templates and click Assign.
Tip:
Step templates are created on the Enterprise Data or Enterprise Project Data page.
