Adding Documents to a Project without the Content Repository
In standard P6 configurations without the optional content repository, you can add project documents directly from your computer or a network server to the project. These documents are available to everyone who has access to the project.
To add a document to a project:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page:
- Click on the project name.
- Click
Add Document.
- In the Add Document dialog box:
- To add a local document, select the File Path option and then enter a path in the file path field.
- To add a document stored online, select the URL option and enter the address of the document in the http:// field.
- Select Add.
Tip:
- You can also add documents in the Documents detail window of the Activities page.
- You cannot add documents to template projects.
