Adding High-Level Project Risks
Add project risks to capture potential threats or opportunities that might impact your project.
Use this method to quickly add a risk to a project. You can enter basic risk information from this page, including ID, Name, Owner, Category, Type, and Status.
To add a high-level project risk:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click on a project, and then click the Risks detail window.
    2. In the Risks detail window:
      • Click "" Add.
      • In the ID field, click and type an ID for the risk.
      • In the Name field, click and type the risk name.
      • In the Type field, double-click and select the type of risk from the list.
      • In the Status field, double-click and select the current status for the risk.
      • In the Category field, double-click, click "" Select, then select a category from the Select Risk Category dialog box, if applicable.
      • In the Owner field, double-click then click "" Select.
    3. In the Select Owner dialog box, select an owner for the risk and click Assign.
    4. On the EPS page, click Save.
