Assigning Activity Code Values to Activities
Assign activity code values to activities to group and filter data.
To assign activity code values:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select the activities to which you want to assign codes.
- Click
Context and select Assign, then select Codes.... - In the Codes panel:
Tip:
- You can also remove code values in the Assign Codes panel.
- You can also assign code values in the Codes detail window.
