Assigning a Risk Scoring Matrix to a Project from the Portfolios Section
You need to assign a risk scoring matrix to a project before it can be used to prioritize risks. Once you assign a scoring matrix to a project, it is available for use from the risk register on the Risks page in the Projects section.
You can assign a risk scoring matrix to a project from multiple locations in the application. Use this method when you are creating or modifying a portfolio.
To assign a risk scoring matrix from the Portfolios section:
Tip:
If the Risk Scoring Matrix field is not visible, click Customize and the field.
