Assigning a Role to a Role Team
Perform these steps to assign a role to a role team. You can assign a role to a role team from the Role Teams tab or the Roles tab. Use this method if you want to view all roles assigned to a particular role team.
To assign a role to a role team:
- On the
Navigation Menu, expand
Resources and click Administration. - On the Resources page, click Role Teams.
- On the Role Teams tab:
- Expand either the Global or User category, and click the role team for which you are assigning a role.
- Click the Roles detail window.
- In the Roles detail window, click Assign....
- In the Assign Role dialog box:
- Click Save.
Tip:
To view all role teams assigned to a particular role, assign a role team to a role from the Roles tab.
