Assigning Documents to Activities
You can assign relevant documents to activities, projects, and WBSs.
To assign documents:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page, select an activity and click the Documents detail window.
    To assign a document to a project or WBS, select a project or WBS in place of an activity.
    1. In the Documents detail window, click Assign....
    2. In the Select Document dialog box, select a document and select Select.
    3. On the Activities page, click Save.
