Assigning Locations to Projects
Assign locations to projects so you can report on projects by location in Primavera Analytics.
To assign a location to a Project:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page, select a project and click the General detail window.
    1. In the General detail window, click "" Select in the Location field.
    2. In the Select Location dialog box, select the appropriate location and click Select.
    3. On the EPS page, click Save.
Tip:
  • You must create locations before you can assign them.
  • You must have the 'Edit Project Details Except Costs/Financials' project privilege to assign locations to projects.
