Assigning Project Codes
Assign project codes to categorize projects.
To assign a project code:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page, select the projects to which you want to assign codes.
- Click
Context and select Assign, then select Codes.... - In the Codes panel:
Tip:
- You can also remove code values in the Assign Codes panel.
- You can also assign code values in the Codes detail window.
