Assigning Project Funding Sources
Configure funding sources to update the amount and fund share of a funding source in a project budget.
To assign a funding source:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page, select a project or EPS to which you want to assign a funding source and click the Funding detail window.
    1. In the Funding detail window, click Assign....
    2. In the Select Funding source dialog box, select a funding source and click Assign.
    3. On the EPS page, click Save.
